Home > Technical > L494 EPB reset |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
Bump - anyone? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Thu Mar 09 2017 9:18pm |
Been-and-dunit Member Since: 15 May 2016 Location: Burton on trent Posts: 145 |
HI Wilf, Took my rear pads out remove epb electric connection and removed calipers to clean ,put all back together with no epb issues. Just make sure epb is off before attempting work , |
Fri Mar 10 2017 7:07pm |
Thanks. Lots of googling and I found a late model Evoque procedure which seems to work. Puts the EPB into "maintenance mode", i.e. fully retracted, while you replace the pads.
Fri Mar 10 2017 9:33pm |
Yes, the Evoque procedure worked.
Sat Mar 11 2017 5:31pm |
mgriffico Member Since: 20 Feb 2019 Location: Chesterfield Posts: 3 |
Wed Feb 20 2019 2:12pm |
I just levered mine back. No twisting required IIRC. Could w ell depend on actual brakes fitted. Mine were Brembos. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Wed Feb 20 2019 8:41pm |
Thanks Wilf, I’ll have a crack at it then. |
Thu Feb 21 2019 10:00am |
