Home > Technical > Restricted Performance!!
djb222
Just started my 2010 RRS 3.0 after a week of inactivity and was greeted by RESTRICTED PERFORMANCE message.
I took it for a short drive and everything seems fine, although message will not go away.
Just wondering if a low battery would cause this message to appear. In the 10 months I've had the car i have had no issues.
David
Post #575441 Sun Feb 17 2019 1:29pm
djb222
As a follow up, thought I'd just check the battery and alternator charging..
Battery reading 12v and with the car ticking over the alternator is reading 14.9v which is fine.
Also the warning message has disappeared...hmmmmmm
Post #575443 Sun Feb 17 2019 1:51pm
geoffsnook
Battery may be on way out Thumbs Up
Post #575464 Sun Feb 17 2019 7:42pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Sometimes it just does it for the hell of it. If the old "reboot the car" eg cycle the ignition doesn't work, then pop it on a code reader and sometimes there are old codes on there that if you clear them down remove the red triangle issue - your local indie will help you out and advise if any exploration of codes is needed and often won't charge just to read codes and clear/advise.
Post #575472 Mon Feb 18 2019 7:45am
annette
Did you read out the codes?
Iidtool does magic Smile
Just ask...
Post #575896 Mon Feb 25 2019 7:34pm
