![]() | Home > Technical > Restricted Performance!! |
djb222 Member Since: 17 Apr 2018 Location: Birmingham Posts: 52 ![]() ![]() ![]() |
As a follow up, thought I'd just check the battery and alternator charging..
Battery may be on way out |
Sometimes it just does it for the hell of it. If the old "reboot the car" eg cycle the ignition doesn't work, then pop it on a code reader and sometimes there are old codes on there that if you clear them down remove the red triangle issue - your local indie will help you out and advise if any exploration of codes is needed and often won't charge just to read codes and clear/advise. |
annette Member Since: 21 Feb 2019 Location: Costa Rica. Country list not working Posts: 7 ![]() |
Did you read out the codes?
