Home > Technical > Part identification
GARYF123
Part identification
Hi all!
My 2007 TDV6 had an advisory on MOT at xmas 'anti roll bar linkage ball joint (play) n/s rear'
It had its service last week at a different garage who reported 'rear track control arms (both) worn. They are been done at this moment but i wondered (hoped!!!) are these the same part?
Post #575266 Thu Feb 14 2019 7:50pm
Brit Plumber
The way I read that is, the ball joint being the joint on the driop links and the track control arms are that, control arms. It may be to late but the garage should be able to sort the drop links while they are replacing the control arms. They may even disconnect the drop links anyway. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #575278 Fri Feb 15 2019 6:46am
Brit Plumber
I think this is what they refer to as a track control arm.
https://www.advancedfactors.co.uk/rear-sus...3895-c.asp 2019 5.0 SC SVA (Current)
Post #575279 Fri Feb 15 2019 6:54am
