Home > Technical > 2.7 tdv6 gearbox oil & filter replacement
Flexzor
Belgium 2009 Range Rover Sport TDV6 HSE Java Black
I want to change the the oil, filter & seals of my gearbox (2.7 tdv6) because i have some slight judder & rpm jumping.
When i check the youtube movies, the exhaust is in the way, however on my 2.7 tdv6 it seems quite easy because no exhaust is crossing.
Can i easily pull out the gearboxpan+ filter? ( i see there is some cross beam of the chassis is relative close to the drain plug side of the oil pan.)
Thanks
Post #574970 Sun Feb 10 2019 7:15pm
No it’s not easy to remove due to the front cross member.
Don’t change the filter.
Just change the oil.
Drain it
Refit plug.
Run engine for about. 20 seconds
Redrain gearbox.
Post #574979 Sun Feb 10 2019 8:03pm
