![]() | Home > Maintenance & Modifications > NAV Screen Protectors |
Prupas Member Since: 08 Jul 2006 Location: Nevada, Reno/ San Francisco Posts: 14 ![]() ![]() ![]() |
Ya I bought one from this company on ebay. So far so good. Cheap and works very well. It is good to see somone from Tahoe around here. Reno myself.
DAVIS Member Since: 27 Dec 2005 Location: Genoa, Nevada Posts: 134 ![]() ![]() ![]() |
Prupas,
Isma Member Since: 08 Apr 2006 Location: Miami, FL Posts: 26 ![]() ![]() |
I also have the same screen protector sold on ebay by screenpatronus; it's invisible and easy to clean.
Havank Member Since: 20 Jun 2006 Location: West Sussex - UK Posts: 691 ![]() |
It looks like that screenprotector issue is an american issue |
Brian Mason Member Since: 31 Aug 2006 Location: Lurking with intent!!! Posts: 5326 ![]() ![]() ![]() |
I read the comments and purchased one on ebay from the USA. I spent ages trying to get the super-thin clingfilm onto the screen but couldn't do so without leaving multiple trapped air-bubbles. Obviously, the American lads are both more patient and more dexterous because I threw the bloody thing into the bin. I'll now just have to be a little more careful when touching the screen than our American friends!! |
Once you place it where you want it...it is best if you use a credit card to remove the bubbles. Slide it along the screen and push them out the sides. Good luck |
Best get it out the bin, Brian |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 ![]() ![]() ![]() |
I bought one on eBay also...yes, there were a few air bubbles after putting it on, but I pushed those out with my fingers to the edges (did not have my credit cards with me....). A few remained after that but have now gone. I suspect from the heat generated by the screen when it is on. Can't say I had any problems with the alignment either - tucked it up to one corner and pressed it down diagonally across the screen surface. The whole thing took about five minutes...including chasing the air bubbles.
I obviously had a bad day then fellas? Screwed it up in a bit of a temper.., but at least I successfuly turned the air blue!!! Bit late now? |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
I use " Martin Fields " screen proctectors for my mobile phones and my son has one fitted to his PSP - they are regarded as quite simply the best out there - period!
I have just emailed Martin Fields for some information on possible products? |
Ok - I have had continuing dialogue with Martin Fields [ email ] they have sent me numerous templates to chech/verify size of screen & protector etc.
Mate can they do any size Screen Protectors?? RRS TDV6 Gone but still around
It would appear so - best thing to do is go to their website and contact them via the contact us link [ as i did ] |
