Home > Technical > ATC (automatic temperature control) module Help!!
Page 3 of 3 <123
dO you have lumber support on your seats? Like an electric window switch on the side? That makes a pump or hiss when pressed? does the drivers one work ?
Yeah a replacement module maybe in idea, although sometimes they require programming, so may not be plug and play.
Also check the grounds near the floor (and to the side of the throttle pedal)
Post #574532 Mon Feb 04 2019 7:39pm
Ziguk
England 2005 Range Rover Sport 4.4 V8 HSE Java Black
Haven’t notice tbh the passenger seat works fine issue is with drivers seat, will check the earths
Thanks
Post #574542 Mon Feb 04 2019 9:34pm
Which switch configuration do you have?
Post #574550 Mon Feb 04 2019 9:58pm
Ziguk
Hi
The top one with the memory buttons
Post #574554 Mon Feb 04 2019 10:15pm
If you have checked all the connections and they are sound, for the sake of 25 quid something like this might be worth a shot.
https://www.ebay.co.uk/itm/Land-Rover-Rang...:rk:1:pf:0
Post #574555 Mon Feb 04 2019 10:25pm
that wouldn't stop the mirrors though.
memory module is clicking too
Post #574561 Mon Feb 04 2019 10:50pm
Surely just because it's clicking doesn't necessarily mean it's working and are the mirrors not linked to the seat memory position in some way?
Post #574569 Mon Feb 04 2019 11:29pm
I agree with you. Yes yes.
Post #574570 Mon Feb 04 2019 11:36pm
If all wiring/connections etc. are sound I guess the options are limited and may have to try either substituting memory module or switch pack.
Post #574574 Tue Feb 05 2019 12:16am
Page 3 of 3 <123
