Home > General > Xenon lights not working... bulbs replaced and still issues
flindersstation
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
Hi there
One of my Xenon dipped headlights is not working so I assumed the bulb. I went to Halfords and got a D2S bulb, came home, took the grill off, took both sets of lights out and followed youtube to take off cap, remove ignitor and replace bulb. All good, until I put them back on. Lights still dont work with new bulb. I swapped the ignitors round and still same issue, so I am thinking an issue with the controller? Any thoughts?
Thanks guys. Smile 2007 RRS 2.7 HSE (Current)
2015 Audi A1 1.4TSI (Current)
2015 Audi A6 2.0 TDI (Gone)
1994 Pajero 2.8 TD (Gone)
Post #574319 Sat Feb 02 2019 2:27pm
Humm. You could swap the left and right lights to be sure it isn’t a power supply problem.
Or it could be a Duff bulb from halfords.
Loosly plug one of the non working bulbs into the rear of the working headlight and see if you have 3 good bulbs
Post #574323 Sat Feb 02 2019 3:08pm
flindersstation
Good thinking! I swapped the units around and the power to both is good. Also cycled through all 3 bulbs and they are all good. Both igniters work. So by a process of elimination it’s pointing to a bad controller or whatever this box of tricks is.... unless some dodgy connections within the light unit. Thanks for your help so far ... I don’t really want to unscrew both of these boxes yet as I may end up with no lights if it goes wrong .... 2007 RRS 2.7 HSE (Current)
Post #574326 Sat Feb 02 2019 4:09pm
flindersstation
Here’s the part I think I need
Post #574327 Sat Feb 02 2019 4:22pm
flindersstation
I thought this might be some kind of controller but it's a headlight ballast... might be same thing Smile
I'm pretty sure this is the cause of the issue and I'll swap them both round tomorrow to make sure that it really is and I'll probably get a replacement here:
https://www.ebay.co.uk/itm/Replacement-for...:rk:6:pf:0 2007 RRS 2.7 HSE (Current)
Post #574329 Sat Feb 02 2019 4:29pm
Disco_Mikey
Replaced a few of them lately. Easy enough to swap over for testing purposes Thumbs Up
Post #574332 Sat Feb 02 2019 4:41pm
You can sometimes get half broken lights off eBay and take if the part you need
Post #574333 Sat Feb 02 2019 4:51pm
flindersstation
Yes, only 3 screws to remove the ballasts. I swapped them round and got the other light working. So now I know I need a new ballast. I now know a lot more about Xenon lights than I did this morning, I thought it was just a simple bulb replacement. This is all easy when you know how! Smile 2007 RRS 2.7 HSE (Current)
Post #574334 Sat Feb 02 2019 5:03pm
flindersstation
Thanks, I will have a look - one of my lenses is clear and one is yellow, so I could also do with getting some new lenses (if that's what you call them... the glass at the front Smile ) 2007 RRS 2.7 HSE (Current)
Post #574335 Sat Feb 02 2019 5:04pm
You need to put the headlight in the oven briefly to remove the glue.
Make sure they fit!
Post #574351 Sat Feb 02 2019 7:04pm
Nigex4x4
United Kingdom 2006 Range Rover Sport TDV6 HSE Arctic Frost
lens cleaning
I watched a youtube vid on renovating headlamps and tried it myself, worked a treat! Might be irrelevant here but you never know. Hope it helps. Nige 2005 RRS HSE Arctic Frost (more like Scotch mist)
"When you are going through Hell - keep going!" Sir W Churchill
Free plumbing advice to fellow sufferers
Post #597036 Thu Mar 26 2020 8:57am
knwatkins
Did you seal the light afterwards Nige? If so, what did you use? Kev
Post #597041 Thu Mar 26 2020 9:37am
Nigex4x4
Hi Kev, no I didn't mate. The vid I watched suggested an array of treatments but he favoured a clear film you can buy. He also used a clear acrylic lacquer. Hope that helps, think he was mexican or something, real pro.
Post #597043 Thu Mar 26 2020 11:06am
