![]() | Home > General > Xenon lights not working... bulbs replaced and still issues |
flindersstation Member Since: 02 Jan 2019 Location: Scottish Highlands Posts: 17 ![]() ![]() ![]() |
Hi there
Good thinking! I swapped the units around and the power to both is good. Also cycled through all 3 bulbs and they are all good. Both igniters work. So by a process of elimination it’s pointing to a bad controller or whatever this box of tricks is.... unless some dodgy connections within the light unit. Thanks for your help so far ... I don’t really want to unscrew both of these boxes yet as I may end up with no lights if it goes wrong .... 2007 RRS 2.7 HSE (Current)
Here’s the part I think I need
I thought this might be some kind of controller but it's a headlight ballast... might be same thing |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4460 ![]() ![]() ![]() |
Replaced a few of them lately. Easy enough to swap over for testing purposes |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
You can sometimes get half broken lights off eBay and take if the part you need |
Yes, only 3 screws to remove the ballasts. I swapped them round and got the other light working. So now I know I need a new ballast. I now know a lot more about Xenon lights than I did this morning, I thought it was just a simple bulb replacement. This is all easy when you know how! ![]() 2015 Audi A1 1.4TSI (Current) 2015 Audi A6 2.0 TDI (Gone) 1994 Pajero 2.8 TD (Gone) |
Thanks, I will have a look - one of my lenses is clear and one is yellow, so I could also do with getting some new lenses (if that's what you call them... the glass at the front ![]() 2015 Audi A1 1.4TSI (Current) 2015 Audi A6 2.0 TDI (Gone) 1994 Pajero 2.8 TD (Gone) |
You need to put the headlight in the oven briefly to remove the glue.
Nigex4x4 Member Since: 17 Jul 2014 Location: scarborough Posts: 22 ![]() ![]() ![]() |
I watched a youtube vid on renovating headlamps and tried it myself, worked a treat! Might be irrelevant here but you never know. Hope it helps. Nige 2005 RRS HSE Arctic Frost (more like Scotch mist) "When you are going through Hell - keep going!" Sir W Churchill Free plumbing advice to fellow sufferers |
Did you seal the light afterwards Nige? If so, what did you use? Kev
Hi Kev, no I didn't mate. The vid I watched suggested an array of treatments but he favoured a clear film you can buy. He also used a clear acrylic lacquer. Hope that helps, think he was mexican or something, real pro.
