![]() | Home > In Car Electronics > Reverse Camera and Parking Sensors not working. |
Is it just a reverse camera you have or surround cameras?
HyndmanD Member Since: 28 Jan 2019 Location: Stockton on Tees Posts: 5 ![]() ![]() ![]() |
Thanks for the reply Brit Plumber,
If it’s just the reverse camera you have, there’s only 2 wires for power and a coax for the signal. The coax is black, about 4mm in diameter and runs from the camera to behind the roof lining in the middle at the rear most point. There it connects to another coax (it’s a disconnect if you’re removing the booot) and runs down the left D pillar (passenger) in the loom, then over the LH wheel arch into the channel under the rear passenger sill cover before turning right into the X wiring loom where it turns left under the centre console. The cable then meets another connector at the front left of the centre console before running to the head unit. I haven’t sussed if it runs direct to the screen or if it runs back to the LH channel and up to the dash.
My rear camera was intermittent when I first got the car. I reseated the connections under the spoiler, put a blob of hot glue on and it has been fine ever since. Kev
Brit, thanks for the very detailed response, it should keep me busy at the weekend. I’ll let you know how I get on, thanks again! |
knwatkins, I had the spoiler off at the weekend and give the connection to the camera a bit of a wiggle while it was in Diagnostics mode but with no joy, it didn’t take long to remove so I’ll give it another go at the weekend, thanks for the info! |
Does it fail when you (if you can) select camera from the screen? 2019 5.0 SC SVA (Current)
When I select the Canera in diagnostic mode, I just get a green bar across the bottom of the screen and diagonal black and white chevrons running across the screen above it. |
I think the camera is live all the time so I think you need to check for power at the camera. 2019 5.0 SC SVA (Current)
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
Sorry to butt in on an old thread, but is the camera in diag mode (fuzzy with a green line) not normal?
