Home > General > Dash trim clips
doyleywood
Dash trim clips
After fitting a stereo upgrade i lost 2 of the clips that hold the trim around the head unit, looking online the only stockist seems to be Powerfull uk, but at £12 for 4? seems a bit expensive, has anyone actually priced these clips from LR ? thanks in advance.
Post #573779 Thu Jan 24 2019 4:26pm
They are about £2.00 each from L/R FYC500040 some of them do tend to fly off never to be seen again. Laughing
Post #573789 Thu Jan 24 2019 8:15pm
doyleywood
thanks for that Thumbs Up
Post #573795 Thu Jan 24 2019 9:46pm
GodivaNige
I lost a couple which pinged off as you have experienced, when I replaced the radio. I found both of them quite easily as they had dropped down to where the centre console trim meets the carpet in the footwells. If you gently ease the plastic away from the carpet, you may be lucky and see them. Worth a try before you stump up the ridiculous price that LR or Powerful UK want for this tiny little piece of spring steel.
Post #573798 Fri Jan 25 2019 12:09am
Brit Plumber
As above, found one there today but I can’t find where it’s from! 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #573799 Fri Jan 25 2019 12:47am
Brit Plumber
Have a look at this seller stuff, he may have something similar.
https://www.ebay.co.uk/itm/10Pcs-Universal...3444579160 2019 5.0 SC SVA (Current)
Post #573800 Fri Jan 25 2019 12:51am
I managed to retrieve some using a magnetic flexible shaft pickup tool, just poked it in various inaccessible places to see if it picked any up.
Post #573835 Sat Jan 26 2019 6:14am
mrluke
I used a few of them . They are not the correct shape on the ends, RR ones are flat where these are like bent round. It will result in the trim piece not going fully back.
Post #573952 Sun Jan 27 2019 5:34pm
