Home > Technical > Telestart T91 FBH - Help needed |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 |
Yes there is 2 settings than need changing in the ccf park heating with remote and park.heating with fuel fires heating. I think from memory.
Sun Jan 20 2019 9:04am |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
You need to edit the CCF and the EUCD
Sun Jan 20 2019 11:21am |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 |
Thought it was my error!
Sun Jan 20 2019 11:54am |
Yes you can ๐๐ |
Sun Jan 20 2019 12:17pm |
Is this right?
Sun Jan 20 2019 12:21pm |
You have timed climate disabled |
Sun Jan 20 2019 2:03pm |
So apart from enabling 'Timed Climate' which I'll go and do now everything is right for times and using the remote? Cheers Laurence. |
Sun Jan 20 2019 3:39pm |
everything else seems to be right laurence
Sun Jan 20 2019 3:41pm |
Cycle the ignition twice,,,? this is where I might have gone wrong before and got all those faults come up? so switch the car off after settings are changed (leave the IID Tool plugged in or not?) then press button once so ignition on then press button again for ignition off. Once again for ignition on then off then I'm good to start? Cheers Laurence. |
Sun Jan 20 2019 3:46pm |
yes leave the iid tool in (it should tell you to cycle the ignition once the ccf has been uploaded anyway
Sun Jan 20 2019 3:50pm |
Now the remote is working.. , switching the fans on but the FBH isn't firing up? so just air from outside being blown in. When I changed the settings earlier the car was doing it's test with the IID still plugged in the FHB fired up I see smoke coming out from under the wheel arch I must have one of the settings wrong - How can this be so hard.... Cheers Laurence. |
Sun Jan 20 2019 4:42pm |
This what Iโve set too
Sun Jan 20 2019 4:55pm |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
Just a guess, but could it be due to the outside temperature, doesn't the FHB only fire up once the temperature drops to a certain level. |
Sun Jan 20 2019 4:59pm |
I think you have your ccf settings right now
Sun Jan 20 2019 5:28pm |
