Home > Technical > Telestart T91 FBH - Help needed
Buster007
Banging Head Banging Head Banging Head Patience not my strong point.....!! But I'll give it a go.. Thumbs Up Thanks Allen... Laughing Laughing Cheers Laurence.
Post #573527 Sun Jan 20 2019 6:59pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
david007 wrote:
Just a guess, but could it be due to the outside temperature, doesn't the FHB only fire up once the temperature drops to a certain level.
When I remember to I use my remote FBH during summer as an engine pre-warmer in an attempt to reduce cold engine wear, and yes where I live our summers are cooler but still double figures and the heater burns away nicely. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #573533 Sun Jan 20 2019 7:40pm
Buster007
How long does it take to get hot? Cheers Laurence.
Post #573542 Sun Jan 20 2019 9:50pm
insiorc
If you mean in the cabin then you certainly know it's been on with 10 minutes running, the full 20 minutes can be nice and comfortable but of course this is all weather temperature related. I've never checked under the bonnet to check temperatures of anything if that is what you meant? 13MY Range Rover Sport Autobiography SDV6 - mine
Post #573544 Sun Jan 20 2019 9:56pm
Bardley
FBH
If the FBH is firing up and producing smoke, then give it a while to sort itself out and get going. It does take a short while to get up to temp.
If the unit then shuts down, it maybe worth using your GAPII to Prime the fuel supply to it ( In the menus), then test run it (again using the GAPII tool).
There's alot of info. here and most subjects and issues covered.
https://www.disco4.com/forum/webasto-fuel-...-vf96.html 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #573557 Mon Jan 21 2019 8:38am
TubaPlayer
Buster007 wrote:
Is this right?
Now got every fault under the sun showing ? What on Earth has happened??
Think I've sorted the faults out? They wasn't showing on the IID Tool so turned off the car let go to sleep and restarted all seems good now.... Bow down
I have found that I sometimes get lots of faults showing up after updating with the IID tool but once the car has been left for 10-15 mins it is ok and all faults have gone.
It gave me heart failure the first time it happened. 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #573576 Mon Jan 21 2019 4:00pm
