Home > Faults & Fixes > SQUEALING NOISE FROM OSF WHEEL AREA
JAMES ALBERT
United Kingdom 2009 Range Rover Sport TDV6 HSE Santorini Black
2009 2.7 TDV6 Squeaking/squealing noise from the OSF wheel area when cornering left. It's driving me mad! I have recently had it jacked up for a few hours on the NSR. Noticed the noise after it was lowered and when i started driving again.
Post #573002 Sun Jan 13 2019 1:49pm
Brit Plumber
Could be anything but I’d start with brakes, could be something foreign stuck between the pad and disc or may be you’ve lost the friction material and you’ve got a backing plate directly onto the disc. If you’re handy with a jack, it’s worth a look. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #573476 Sun Jan 20 2019 8:19am
M9G UK
Did you find out what this was?
Is it more of a creaking? I have exactly what you are describing, got knocking aswell when going over bumps, think its probably all related i.e. bushes so have it booked in to garage next Tuesday as my old bones don't like laying on cold roads any more. I'll let you know what they find in case you have the same fault.
M9G UK
Post #574308 Sat Feb 02 2019 11:45am
GSJ
Wales 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Hi there,
Been a while since I’ve been on the forum but camemacross this post and thought I’d share.
I had EXACTLY the same symptoms and screaching noise coming from the front of my 2006 RRS.
I’m willing to put a sizeable bet on this noise/ issue your experiencing is due to your wheel hub (s).
Changed mine after advice from specialist and noise went immediately.
Hope this helps
Gareth
Post #576101 Fri Mar 01 2019 9:58am
GSJ
Ps - apologies for typos and grammar - on bumpy train, on small phone screen which is cracked 🤦🏼‍♂️
Post #576102 Fri Mar 01 2019 9:59am
M9G UK
Thanks, mine was the nearside drives haft, the roller bearings on the inner cv joint were completely non-existant 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Xtrons Android head unit
Smile
Post #576103 Fri Mar 01 2019 10:01am
GSJ
Glad it’s sorted 👍🏻
Post #576104 Fri Mar 01 2019 10:09am
M9G UK
Cheers Thumbs Up 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Smile
Post #576106 Fri Mar 01 2019 10:10am
