Home > Technical > IID Tool - what settings did you add/change?
Page 2 of 3 <123>
knwatkins
Theoretically that should work Col. Although it may be worth playing it safe and installing two diodes per headlamp unit to prevent the ignition live and the sidelight feed feeding back to each other ie. When the sidelights are turned on, you also don't want power switched back to the ignition live also.
Personally, the mod in the fusebox was the most convenient for me however. It's simply two wires which are plug and play with no changes made to the existing loom. I also added a little DPST switch so that the functionality can be switched off when the vehicle is taken in to a garage. This avoids any confusion when they can't figure out how to turn the lights off. Laughing Kev
Post #573108 Tue Jan 15 2019 7:32am
Buster007
This exactly what I was looking for thank you! Not pretending to know anything about electrics I’m guessing the switch you installed was an inline switch on the patch lead? What switch do I need to get and any pictures of yours... Thumbs Up Cheers Laurence.
Post #573117 Tue Jan 15 2019 9:46am
knwatkins
That's right Buster. It's a single switch that switches both patch leads. It's a double pole switch so it's effectively two switches controlled by a single button. The switch I used was from Amazon, they come in a pack of 10 for £1.70....
https://www.amazon.co.uk/gp/product/B00IID...&psc=1
I used some 'add a circuit' fuse holders from the internet, however, it's very tight to fit them in and not ideal for access to other fuses once installed. If I did it again, I would use the fuse with a breakout wire from Halfords...
https://www.halfords.com/workshop-tools/ga...amp-hfs280
I've just nipped out to the vehicle to take some pictures for you. Unfortunately, it's not clear to see so I have taken some pictures of the fuse box printout I used to guide me when doing the mod with the fuses highlighted....
Fuse 49 > Fuse 24
Fuse 50 > Fuse 25
Hope this helps! Kev
Post #573141 Tue Jan 15 2019 4:19pm
could you explain for others what you have done there.
Have you disconnected the side light feed and then applied ignition to the fuse holder output ?
Post #573145 Tue Jan 15 2019 6:08pm
Buster007
I assume the fuse box in question is the PASSENGER COMPARTMENT FUSE BOX and not the engine bay fuse box?
Can this be fitted without disconnecting the battery? Cheers Laurence.
Post #573157 Tue Jan 15 2019 8:09pm
If you have simply bridged fuse 24 & 49 together as well as 50 & 29 with a switch between the two pairs which disconnects the ignition live feeds from 49 & 50 I understand that, but still not sure what happens when you turn the headlights etc. on in normal use as would this not give a power back feed to the circuits as I thought in my earlier reply. As said not auto electrician so abit unsure. Only if you have to change the new switch position each time would it not be easier just to switch sidelights on every time you start the car?
Post #573162 Tue Jan 15 2019 8:40pm
The only thing I changed with the IID was turning off auto wipers. It meant that the intermittent wipe worked as an intermittent with the rate selectable on the column. I hate auto wipers. 2012 SDV6 - it's missing a couple of cylinders
Post #573166 Tue Jan 15 2019 9:02pm
knwatkins
Yes, this is the interior fusebox behind the glovebox. All headlight functionality remains the same.
The sidelight feeds are not disconnected. They remain in place and therefore all existing functionality remains the same. The ignition (AFL) feeds are routed straight through to the sidelight feeds.
It's a good point about the diodes Col, I may also implement this when I get a spare 5 mins as I have some leftover diodes from my rear map lights mod that now come on when the doors open Smile
Although, I have had this now in place since October with no negative consequences. This is also a common mod within disco3/4 community.
The fairy lights are now on permanently as long as the car is awake. For example, lights switched off...
Fairy lights remain on...
The rear lights remain on also but it's not a problem for me. Kev
Post #573174 Tue Jan 15 2019 10:37pm
Got it now, does seem easier way than cutting into harness,would have thought after a few months if there were any return feed issues it would have showed up by now. Thumbs Up
Post #573175 Tue Jan 15 2019 10:47pm
Buster007
Does the glove box come out for easy access? Cheers Laurence.
Post #573177 Tue Jan 15 2019 11:06pm
What happens if you try to leave parking lights on ??
Post #573178 Tue Jan 15 2019 11:18pm
knwatkins
To get to the passenger compartment fusebox, you simply push both support stays inwards. The glovebox then hinges down into the footwell.
All other lighting functionality remains the same Andy. It's just the fairy lights are on whenever the car is awake. Kev
Post #573189 Wed Jan 16 2019 7:20am
Xrover
United States 2008 Range Rover Sport 4.4 V8 HSE Zermatt Silver
I have definitely got my money’s worth from my IID Tool.
Things I have done with it on my 08 RRS.
Suspension Calibration and custom ride heights.
Turned off the problematic TPMS system
Disabled the Headlamp Washers
Changed the time the dome lights remain on after exiting (15 sec.)
Updated the FW for Transmission and Transfer Case
Performed calibration procedure for Transfer Case
Check and clear codes
Re calibrated steering angle sensor
Used suspension tight tolerance mode for wheel alignment
Reset engine and transmission adaptations after induction cleaning and transmission service
Checked live values for various components
Thumbs Up 2006 LR3 HSE
2008 RRS HSE
Post #573646 Tue Jan 22 2019 6:44pm
Baz0195
England 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi xrover. Do you have a list of what changes/modifications you can do on a 2010 mate. Question
or anyone else that can help Thumbs Up
Post #577256 Sun Mar 17 2019 6:06pm
Xrover
Go on the GAP website and look up your vehicle to see what all you can do with
https://www.gap-diagnostic.com/products/iidtool/ 2006 LR3 HSE
2008 RRS HSE
Post #577261 Sun Mar 17 2019 6:38pm
Page 2 of 3 <123>
