Home > Faults & Fixes > Central locking life of its own when keys out the ignition
XSPRS
United Kingdom 2005 Range Rover Sport Supercharged Siberian Silver
Yep have a sunroof.
Drying out as we speak. as its not rained yesterday, the fault simply puffed the fan once and nothing else. but like u say the damage might be done. will see if i can trace the leak while its drying.
Post #572209 Wed Jan 02 2019 12:41pm
XSPRS
Both drain holes were plugged with crap and not draining properly.
Have now cleaned out and they drain freely which must help.
Drying out foot well as we speak and last time i started it and turned it off.... No issue
So i am crossing everything its going to be OK.
If after everything i spent on a new battery i dont mind.
Many thanks for the assistance hopefully others might see this if they have similar Thumbs Up
Post #572218 Wed Jan 02 2019 2:22pm
Brit Plumber
I hope it just takes a good drying to sort. Keep an eye on the sunroof drains as I know a lot of posts on here comment on replacing them. I get the impression that they can deteriorate quite rapidly. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #572219 Wed Jan 02 2019 2:25pm
XSPRS
Where is the exact location of the BCM ? is it behind the fuse board under the glove box.
Post #572236 Wed Jan 02 2019 6:02pm
Brit Plumber
I actually don’t know but have seen threads intimating that is in that area or possibly the main fuse box. I’ve also read that an issue with the instrument cluster can give similar symptoms as the low speed can bus is connected to it. As you mentioned the drivers footwell being damp, it may be worth a check in that area. 2019 5.0 SC SVA (Current)
Post #572238 Wed Jan 02 2019 6:09pm
XSPRS
Well looks like I dodged a bullet.
Been drying the interior until now and she is now back to normal.
My bad for saying drivers side I meant passenger.
Many thanks for helping Thumbs Up
Post #572300 Thu Jan 03 2019 7:22pm
TubaPlayer
Finger Crossed 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #572301 Thu Jan 03 2019 7:24pm
Brit Plumber
Passenger footwell makes sense then. Water in the fuse box/BCM then. Keep checking after heavy rain and keeping the sunroof drains clear should cure it for good.
Just keep it in the back of your mind that I’ve read a lot of people change out the drain pipes so there is probably a reason why. If they appear clear but you still get a wetness, you may need to change in the future.
Thumbs Up 2019 5.0 SC SVA (Current)
Post #572303 Thu Jan 03 2019 7:36pm
XSPRS
Yes worthy of a change I think.
Hopefully this thread I'll be of help to others.
Post #572324 Thu Jan 03 2019 9:25pm
cheet
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
I have had the same problem. Central locking having a mind of its own, various faults flashing up on the dash display.
On the radio display `Vehicle Fault system shutting down` was also shown before the satnav screen and radio shut down.
Everything would clear and reset only to happen a short while later.
I found a guy trading as TOTALTRONICS.COM in Rugby who sorted the problem for me. He offers a while you wait service if you pre book and will also remove the instrument cluster if you take the car to him.
Post #578373 Wed Apr 03 2019 7:18pm
cheet
Post #578374 Wed Apr 03 2019 7:19pm
