Home > Maintenance & Modifications > What setting for CTEK charger?
Brit Plumber
Can anyone tell me what setting I should set my CTEK charger to for charging this battery. I’m guessing my battery isn’t an AGM.
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #571945 Sat Dec 29 2018 7:16pm
Just the Car icon on.
Recon should only be used twice a year max
Post #571948 Sat Dec 29 2018 7:37pm
Buckster
Disagree, you should have a AGM battery so AGM icon and car icon both on together Wink 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #571951 Sat Dec 29 2018 8:29pm
Brit Plumber
I assumed as my battery has screw caps that it was a wet battery, is that not the case?
I’m thinking my battery is goosed as it is now 7 years old and won’t turn the engine over. I’ve got it on charge now and will see how it is in the A.M. if it crap, I’ll probably buy a replacement. I think the car deserves a late Christmas pressie. 2019 5.0 SC SVA (Current)
Post #571954 Sat Dec 29 2018 8:40pm
Buckster
Does it say AGM on the battery? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #571978 Sun Dec 30 2018 12:46pm
Lindab
That battery looks like there are the plastic stoppers in it for topping up. It is not AGM. As Andy says only car icon. Its worth trying the Recon setting if you are thinking of getting a new one. Nothing lost, nothing gained
Post #571985 Sun Dec 30 2018 2:45pm
Brit Plumber
No mention of AGM anywhere. I charged it over night on car and recon, this morning (12 hours later) I checked and it was on no. 6 recon. Then an hour later it was back down to no. 4 so I tried starting it and it was fine. If it starts playing up again I’m getting a new battery. 2019 5.0 SC SVA (Current)
Post #571989 Sun Dec 30 2018 3:25pm
it really should get to the green light near the end. (one before last)
Maybe you opened the doors to drop it back down to 4.
Post #571993 Sun Dec 30 2018 5:02pm
