![]() | Home > Maintenance & Modifications > What setting for CTEK charger? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5007 ![]() ![]() ![]() |
Just the Car icon on.
Disagree, you should have a AGM battery so AGM icon and car icon both on together |
I assumed as my battery has screw caps that it was a wet battery, is that not the case?
Does it say AGM on the battery? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 913 ![]() ![]() |
That battery looks like there are the plastic stoppers in it for topping up. It is not AGM. As Andy says only car icon. Its worth trying the Recon setting if you are thinking of getting a new one. Nothing lost, nothing gained |
No mention of AGM anywhere. I charged it over night on car and recon, this morning (12 hours later) I checked and it was on no. 6 recon. Then an hour later it was back down to no. 4 so I tried starting it and it was fine. If it starts playing up again I’m getting a new battery. 2019 5.0 SC SVA (Current)
it really should get to the green light near the end. (one before last)
