![]() | Home > General (L494) > Low Battery Warning (Again) |
I don't know if it is of any help, but if you have a look at this it shows how L/R fit/install the battery charging kit, which is I believe a rebranded ctek.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 919 ![]() ![]() |
philmw, Why do Ctek say only to use one extension cable. I emailed them to ask if two were ok & they said no, only one. It's in their interest to sell two, so there must be a reason???????????? |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
Easier for them to say not to.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
Well 12.3 is only 70% charge, a reading of 12.6+ is 100% charged.
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
Red flashing light in Dash on the right is Alarm light. SVR 2018 in Santorini Black. |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
That does sound as though your battery is on the way out. Regular use of Ctek is probably keeping it going.
Both batteries were replaced a few months ago |
Maybe it is the Ctek? As I said above check the actual voltage, maybe the Ctek is wrong regarding the 12.3 volts.
If you’ve had to have both batteries changed and you still have problems after a 160 mile trip sounds like the power management unit is not doing its stuff and not powering down properly. Do have have a Tracker or daahcam or anything 3rd party connected? Did the garage measure the parasitic drain? Is it parked in a garage or outside? May sound silly, but try parking it somewhere else for a while. There used to be problems with security lights and telephone masts keeping the car alive and not shutting down fully. |
Good to hear that it seems to have settled down.
Well here we are again. Low battery warning back |
So now you have the Stop/Start working and that worry fixed you can start worrying about oil dilution every time you stop and restart |
