![]() | Home > General > ENGINE SYSTEM FAULT WARNING DISPLAY |
Removed |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 473 ![]() ![]() |
See if there is a Terraclean company near you that cleans the EGR's & DFP,
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 ![]() ![]() |
I had a Terraclean done on my Jag as it was showing EGR and DPF faults, it worked great. 2016 Black SDV8 Autobiography
ratty2828 Member Since: 07 Nov 2018 Location: southampton Posts: 12 ![]() ![]() ![]() |
Thanks for replies guys,took car to Terraclean garage today he said it wasn't the EGR VALVE but was the Turbo so don't know what to do now |
Zilch Member Since: 20 Mar 2006 Location: Sydney, sometimes the Whitsundays Posts: 2835 ![]() ![]() ![]() |
not sure about the TDv8 but the V6's had some issues with the Turbo actuators sticking..
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 950 ![]() ![]() ![]() |
I had issues similar to this,, you don't say what mileage is on your car though. Normally EGR valves are not so much of a problem on the V8 compared to the V6, but saying that I suffered engine light and reduced performance issues at around the 95k mls mark. Had to replace the valve in question,, one thing I will say, if you have to replace them do both. I only replaced one and a couple of mouths later the other failed,, you will save money by doing both at once. 2010 RRS, TDV8
My TDV8 had the EGRs changed at over 150k miles and that was only because they had to come out to allow access to do something else - may as well change them in that situation! They weren't throwing any errors up to that point.
