Home > General > ENGINE SYSTEM FAULT WARNING DISPLAY
ratty2828
England 2007 Range Rover Sport TDV8 HSE Java Black
Hello Guys new to this site so please bear with me have a RRsport 2007 3.6D wee problem I need help with got the warning ENGINE SYSTEM FAULT took it to a couple of small garages they put it on the computer and says EGR valves need replaced but was to big a job for them the nearest RR garage is over 100 mls away just want to know if there is someway to put the warning message off till I can get it fixed
Thanks
Post #570211 Fri Nov 30 2018 6:01pm
Removed
Post #570212 Fri Nov 30 2018 6:09pm
Autobiography1969
See if there is a Terraclean company near you that cleans the EGR's & DFP,
I had previous car's EGR done and it was only around £130..
Not 100% sure it can be done but worth an ask..
May be an option for you on this one..
Good Luck ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #570214 Fri Nov 30 2018 6:17pm
TubaPlayer
I had a Terraclean done on my Jag as it was showing EGR and DPF faults, it worked great. 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #570215 Fri Nov 30 2018 6:28pm
ratty2828
Thanks for replies guys,took car to Terraclean garage today he said it wasn't the EGR VALVE but was the Turbo so don't know what to do now
Post #570221 Fri Nov 30 2018 7:07pm
Zilch
Australia 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
not sure about the TDv8 but the V6's had some issues with the Turbo actuators sticking..
believed there was a mod/tech notice for it Another Pommie Bar Steward down under
MY20 Defender 110 SE P400 Eiger/Ebony
MY10 3.0 RRS TDv6 Fuji/Ebony/Anigre
Post #570345 Mon Dec 03 2018 12:07pm
gogsy1956
I had issues similar to this,, you don't say what mileage is on your car though. Normally EGR valves are not so much of a problem on the V8 compared to the V6, but saying that I suffered engine light and reduced performance issues at around the 95k mls mark. Had to replace the valve in question,, one thing I will say, if you have to replace them do both. I only replaced one and a couple of mouths later the other failed,, you will save money by doing both at once. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #570367 Mon Dec 03 2018 5:09pm
My TDV8 had the EGRs changed at over 150k miles and that was only because they had to come out to allow access to do something else - may as well change them in that situation! They weren't throwing any errors up to that point.
As for the OP's question - I'm not sure you can disable the warning because it's emissions related. You can blank them and get them coded out but that's a remap job. 2012 SDV6 - it's missing a couple of cylinders
Post #570369 Mon Dec 03 2018 5:19pm
