Home > Maintenance & Modifications > L320 Sunroof ECU |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Iv'e not used one myself, but there are companies who will repair ECU's for a fraction of the price of a new one. My lad had a repair on the ECU on his Civic type R after which it was fine, albeit his is a rather unsophisticated ek9. |
Thu Nov 29 2018 7:03pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
all part sales are a rip off
Thu Nov 29 2018 9:00pm |
If you ebay search L320 sunroof motor you’re looking at £200 to £300! If you search FIAT, Renault etc. £30 to £40!!!
Thu Nov 29 2018 10:32pm |
Or a Honda Civic Motor for £25 free p&p
Thu Nov 29 2018 10:56pm |
It will be specific for rr can bus I expect. |
Thu Nov 29 2018 11:38pm |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
A cunning-plan ruined by reality! If the ECU was good but the motor kapput this would have been a good route to take. Cheers Still, interesting that Webasto do these as well as heaters, |
Fri Nov 30 2018 6:19am |
Could a competent person with the knowledge to download from the chip reprogramme the replacement with the software from the original? The guy on the Disco 3 forum does this with the FFRR L322 clocks into a L320. If it’s £300 versus £30 + a reprogramme it would still be worth it. Maybe even worth just have a spare for the mechanicals. 2019 5.0 SC SVA (Current)
Fri Nov 30 2018 8:22am |
what I tend to do with these things, if your cleaver. and I suspect you are!
Fri Nov 30 2018 12:41pm |
^^^good idea.
Fri Nov 30 2018 1:23pm |
...can anyone suggest where I might get a wiring diagram / pin-out? I don't have the rights on Topix and Google has let me down.
Fri Nov 30 2018 2:20pm |
switch is negative switch
Fri Nov 30 2018 3:08pm |
Fri Nov 30 2018 4:57pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
Fri Nov 30 2018 8:18pm |
Thanks. |
Fri Nov 30 2018 8:58pm |
