Home > Maintenance & Modifications > Wheels spacers
Paul JR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Wheels spacers
Hiya all I’m new here I have a 2012 rrs autobiography with 22” wheels on it I’m looking to put hub centric spacers on the wheels to fill the arches out what size would be best suited to 22” wheels with 285/35/22 tyres
Post #569844 Mon Nov 26 2018 11:21pm
Autobiography1969
The process is fairly simple mate,
Get a straight piece of wood, spirit level and a measure,
Put the wood against the wheel arch,
make sure its straight using the spirit level,
then measure from the inside edge of the wood to the tyre
at its widest point, this is the gap your looking to fill..
Then look for the spacers that are the size you require..
Happy hunting.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #569848 Mon Nov 26 2018 11:47pm
Tyrefitter
30mm is fine & fills the arches nicely,I fitted 30mm on my L494 & I also fitted 30mm on my friends L320 2012 AB & they also make the car look better,I’ll try get some pics of my friends car from the rear today as he is only up the road from me.We have only fitted them to the rear as 30mm on the fronts was too much.This is it from the side which doesn’t really help much.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #569854 Tue Nov 27 2018 5:34am
Paul JR
Hiya thanks for your reply mate I will go with 30 mm on the rear then looks great
Post #569855 Tue Nov 27 2018 6:42am
Tyrefitter
Paul,,these are the ones I fitted,i bought 4 as I was going to fit all 4 but when I put a set on the front the wheels stuck out too much as ive got aftermarket alloys on with a offset of 45 & the originals which are now on the friends car are 53 so their is 8mm difference,so when my mate came in for my old wheels fitting he had the other 2 spacers fitted to his cars rear.You could have a look on ebay & try find just 2 spacers but they are sometimes as much money,unless you know someone with a RRS that wants to share the cost & have 2 each.
https://www.ebay.co.uk/itm/RANGE-ROVER-SPO...2545133126
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #569860 Tue Nov 27 2018 7:47am
Oldandconfused
Don't forget to ask your insurance company if they consider it to be a notifiable modification.
Post #569864 Tue Nov 27 2018 8:21am
Paul JR
Thanks mate would I by any chance get a 15 mm spacer on the fronts to even the front axle up with the rears with 30 mm spacers on also looking at your mates black rr/s the wheels on his look exactly the same as my wheels except for the colour
Post #569933 Tue Nov 27 2018 6:12pm
Tyrefitter
The wheels are off my RRS2,,I suppose you could put 15mm spacer on the front,I’ve got my mates coming in tomorrow to have his 20’s put back on as I’ve just fitted 4x general grabber winter tyres on them,I’ll measure the distance between wheel & arch for you on the fronts as I have a tool to do it.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #569937 Tue Nov 27 2018 6:27pm
Paul JR
If you would mate I’d be very greatfull even a 20 mm spacer only I have noticed that the n15 mm spacers seem to be a lot more expensive than the 20 mm ones 30 mm seem to be the cheaper ones
Post #569939 Tue Nov 27 2018 6:36pm
Tyrefitter
Here you are Paul
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #570020 Wed Nov 28 2018 6:24pm
Paul JR
Thanks for pics are there any issues with tyres rubbing the arches when it’s lowered mate also did you get chance to see what spacer I could fit on the fronts
Post #570023 Wed Nov 28 2018 6:48pm
Tyrefitter
No rubbing of the arches when lowered,,the fronts you’ll probably only need 5-10mm spacers as their isn’t much room for any thicker ones.
Andy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #570024 Wed Nov 28 2018 7:08pm
Paul JR
Ok thanks for that mate
Post #570033 Wed Nov 28 2018 7:51pm
