Home > Maintenance & Modifications > Wheels spacers |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 470 |
The process is fairly simple mate,
Mon Nov 26 2018 11:47pm |
30mm is fine & fills the arches nicely,I fitted 30mm on my L494 & I also fitted 30mm on my friends L320 2012 AB & they also make the car look better,I’ll try get some pics of my friends car from the rear today as he is only up the road from me.We have only fitted them to the rear as 30mm on the fronts was too much.This is it from the side which doesn’t really help much.
Tue Nov 27 2018 5:34am |
Paul JR Member Since: 26 Nov 2018 Location: Walsall Posts: 7 |
Hiya thanks for your reply mate I will go with 30 mm on the rear then looks great |
Tue Nov 27 2018 6:42am |
Paul,,these are the ones I fitted,i bought 4 as I was going to fit all 4 but when I put a set on the front the wheels stuck out too much as ive got aftermarket alloys on with a offset of 45 & the originals which are now on the friends car are 53 so their is 8mm difference,so when my mate came in for my old wheels fitting he had the other 2 spacers fitted to his cars rear.You could have a look on ebay & try find just 2 spacers but they are sometimes as much money,unless you know someone with a RRS that wants to share the cost & have 2 each.
Tue Nov 27 2018 7:47am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Don't forget to ask your insurance company if they consider it to be a notifiable modification. |
Tue Nov 27 2018 8:21am |
Thanks mate would I by any chance get a 15 mm spacer on the fronts to even the front axle up with the rears with 30 mm spacers on also looking at your mates black rr/s the wheels on his look exactly the same as my wheels except for the colour |
Tue Nov 27 2018 6:12pm |
The wheels are off my RRS2,,I suppose you could put 15mm spacer on the front,I’ve got my mates coming in tomorrow to have his 20’s put back on as I’ve just fitted 4x general grabber winter tyres on them,I’ll measure the distance between wheel & arch for you on the fronts as I have a tool to do it.
Tue Nov 27 2018 6:27pm |
If you would mate I’d be very greatfull even a 20 mm spacer only I have noticed that the n15 mm spacers seem to be a lot more expensive than the 20 mm ones 30 mm seem to be the cheaper ones |
Tue Nov 27 2018 6:36pm |
Here you are Paul
Wed Nov 28 2018 6:24pm |
Thanks for pics are there any issues with tyres rubbing the arches when it’s lowered mate also did you get chance to see what spacer I could fit on the fronts |
Wed Nov 28 2018 6:48pm |
No rubbing of the arches when lowered,,the fronts you’ll probably only need 5-10mm spacers as their isn’t much room for any thicker ones.
Wed Nov 28 2018 7:08pm |
Ok thanks for that mate |
Wed Nov 28 2018 7:51pm |
