Home > Faults & Fixes > No front or rear demisters |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
How healthy is your battery? The reason I ask is when I got mine, the heated screen wasn't working, shortly afterwards the battery gave up the ghost. New battery and everything works. This time of year the electrical draw is as high as it's going to get with heated seats, screens, heater on full, lights on etc, and from what I understand, the car will decide it can't power everything so doesn't. |
Thu Nov 22 2018 1:10pm |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
I think (hope) the battery is OK. Its just had to have a new alternator. I reckon I may just buy a new battery soon anyway.
Thu Nov 22 2018 10:01pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Have a look here:
Fri Nov 23 2018 12:50am |
This car is not going to plan.. Ive also noticed that the passenger side Air vents only push out cold air while the driver side is nice a nd and warm.
Fri Nov 23 2018 1:16pm |
Thanks for that link. Low and behold the connection under the spoiler was all corroded so I cut it out and reconnected the wires.
Fri Nov 30 2018 10:12am |
My left front demister failed and thanks to another forum member, I checked the big J fuses in the Engine bay fuse box and sure enough, it was blown. Apparently it’s a known issue and a replacement of another design is recommended. My original had 2 fuseable links whereas the replacement was one heavier gauge link. Works fine now. 2019 5.0 SC SVA (Current)
Fri Nov 30 2018 5:15pm |
