Home > Faults & Fixes > No front or rear demisters
Themoog
Chuffing ell..
I noticed this morning with the frost that the front and rear demister don't work. I've done a bit of research and in a minute I'm going to remove the rear spoiler to check the connection. A relay clicks when the button is pressed so something is happening.
When i pressed the button for the front demister the overhead light dimmed for a second (the door was open at the time) but the frost didn't melt within a minute or two. Apart from fuses what else do I need to look for?
Post #569446 Thu Nov 22 2018 1:04pm
Oldandconfused
How healthy is your battery? The reason I ask is when I got mine, the heated screen wasn't working, shortly afterwards the battery gave up the ghost. New battery and everything works. This time of year the electrical draw is as high as it's going to get with heated seats, screens, heater on full, lights on etc, and from what I understand, the car will decide it can't power everything so doesn't.
Post #569447 Thu Nov 22 2018 1:10pm
Themoog
I think (hope) the battery is OK. Its just had to have a new alternator. I reckon I may just buy a new battery soon anyway.
I tried to get the spoiler off today but a combination of cold, rain, light and not really knowing how it comes off made me give up and go and hang a 30kg oak door instead..
Maybe tomorrow..
Post #569493 Thu Nov 22 2018 10:01pm
Have a look here:
http://www.rrsport.co.uk/forum/topic29082.html
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #569504 Fri Nov 23 2018 12:50am
Themoog
This car is not going to plan.. Ive also noticed that the passenger side Air vents only push out cold air while the driver side is nice a nd and warm.
Whats going on there then..
Post #569539 Fri Nov 23 2018 1:16pm
Themoog
Thanks for that link. Low and behold the connection under the spoiler was all corroded so I cut it out and reconnected the wires.
As for the front demister I don't know yet along with the stuck heater vent heat differential.
Post #570176 Fri Nov 30 2018 10:12am
Brit Plumber
My left front demister failed and thanks to another forum member, I checked the big J fuses in the Engine bay fuse box and sure enough, it was blown. Apparently it’s a known issue and a replacement of another design is recommended. My original had 2 fuseable links whereas the replacement was one heavier gauge link. Works fine now. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #570209 Fri Nov 30 2018 5:15pm
