Home > Wheels & Tyres > Will these tyres fit my L320? |
MartinsTDV8 Member Since: 22 Feb 2017 Location: County of Sutherland. Posts: 140 |
Folks
Wed Nov 21 2018 5:23pm |
If this site is correct, there’s a big difference.
Thu Nov 22 2018 1:54am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Just a guess but it does look to me that they would be very tight. The extra height from Brit Plumber's post does seem quite a difference. I have a TDV8 with Brembos and 275x40x20s, and just looking at the gap between the tyre and the wheel arch makes me think you may get some problems. How about selecting Access height on the suspension then turning your wheels to full lock. It might then give you an idea of the space you've got to play with.
Thu Nov 22 2018 7:56am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
The 255/55R20 have a diameter of 775mm. My car has 265/60R18 and they also have a diameter of 775mm - I have no clearance issues at all from access height to super extended and with tyres 10mm wider I have no touching so there will not be an issue.
Thu Nov 22 2018 8:17am |
According to that website 225/55r20 have a diameter of 787mm not 775 which is 13mm difference. Not much in it compared to 58mm in the OPs question. They may fit but what speed difference will it create on the speedo? 2019 5.0 SC SVA (Current)
Thu Nov 22 2018 11:27am |
Thanks folks but without trying one on and having it fitted, I just cant tell. They do look massive compared to my current tyres, so I will give them a miss.
Thu Nov 22 2018 5:27pm |
Yes you are correct I misread the numbers - and the tyre is 255 wide not 225. [/i] 07MY RRS TDV6 Arctic Frost Aspen Interior |
Thu Nov 22 2018 11:55pm |
https://www.disco3.co.uk/forum/swap-rrs-d4...35d4a75170
Mon Nov 26 2018 7:06pm |
