Home > Wheels & Tyres > Will these tyres fit my L320?
MartinsTDV8
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Folks
I have been offered through my work a set of All weather 255/55/20 tyres from a much newer RR. Whistle
I currently have 275/40/20’s on the TDV8 with Brembos on the front.
Will they fit without causing any rubbing and or clearance issues?
Clearly they will effect the speedo reading, but I wouldn’t have thought it would be by much. Previously owned 1999 Disco 2 TD5
Disco 3 HSE TDV6 2007
Gone 2007 TDV8 RRS1 in Buckingham Blue.
How do know if the knocking at the front has been sorted?
You can hear the knocking at the rear better
Post #569384 Wed Nov 21 2018 5:23pm
Buckster
Cant see why not, same size as a Disco 4 runs on 20” wheels I believe 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #569402 Wed Nov 21 2018 9:00pm
Brit Plumber
If this site is correct, there’s a big difference.
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #569420 Thu Nov 22 2018 1:54am
Eaters
Just a guess but it does look to me that they would be very tight. The extra height from Brit Plumber's post does seem quite a difference. I have a TDV8 with Brembos and 275x40x20s, and just looking at the gap between the tyre and the wheel arch makes me think you may get some problems. How about selecting Access height on the suspension then turning your wheels to full lock. It might then give you an idea of the space you've got to play with.
Alternatively, and of course the best answer, is to get one fitted in order to check before you part with any money. After my experience with wheels and tyres (documented elsewhere on here) I'd be very cautious. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #569422 Thu Nov 22 2018 7:56am
garrycol
Australia
The 255/55R20 have a diameter of 775mm. My car has 265/60R18 and they also have a diameter of 775mm - I have no clearance issues at all from access height to super extended and with tyres 10mm wider I have no touching so there will not be an issue.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #569425 Thu Nov 22 2018 8:17am
Brit Plumber
According to that website 225/55r20 have a diameter of 787mm not 775 which is 13mm difference. Not much in it compared to 58mm in the OPs question. They may fit but what speed difference will it create on the speedo? 2019 5.0 SC SVA (Current)
Post #569432 Thu Nov 22 2018 11:27am
MartinsTDV8
Thanks folks but without trying one on and having it fitted, I just cant tell. They do look massive compared to my current tyres, so I will give them a miss.
Bit of a mute point as the Censored is currently sat in the works car park refusing to statrt Censored Big Cry Previously owned 1999 Disco 2 TD5
Post #569465 Thu Nov 22 2018 5:27pm
garrycol
Australia
Yes you are correct I misread the numbers - and the tyre is 255 wide not 225.
[/i] 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #569502 Thu Nov 22 2018 11:55pm
Buckster
https://www.disco3.co.uk/forum/swap-rrs-d4...35d4a75170
Seems this Sport member runs the size you asking about Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #569810 Mon Nov 26 2018 7:06pm
