Home > Faults & Fixes > Suspension fault. Normal height only
Page 1 of 3 123>
Plazmapete
Over the past week I've had suspension fault normal height only. Come up 4 or 5 times a day. If I switch off and back on again it goes away for a while. Could it be the compressor on the way out or an air leak. ?? New alternator.
Gearbox flush.
Post #569101 Fri Nov 16 2018 9:28pm
Cymruambyth
Wales
Could you not get the codes read somewhere...give you a better idea Thumbs Up Steve.
Post #569126 Sat Nov 17 2018 1:12pm
geoffsnook
How old is your battery Whistle
Post #569140 Sat Nov 17 2018 4:20pm
Plazmapete
Battery only 3 years old. Car starts first time every day. Have noticed it takes a while to raise to off road height somtimes. Also if car left for a couple of days the suspension has dropped. New alternator.
Gearbox flush.
Post #569162 Sat Nov 17 2018 11:07pm
Slim444
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Had exactly the same on mine with the warning a couple of months back. It happened sometimes after I had altered the ride height (rarely), and rear nearside corner would sit about 25mm lower than the rest after reversing. Would clear after switching off engine and restarting after a minute or so. Compressor fault, replaced under Marshall Warranty- worth every penny!! You can't see the eyes of the demon until him come callin'
Post #569189 Sun Nov 18 2018 6:48pm
loadshifter
United Kingdom 2009 Range Rover Sport TDV8 HSE Orkney Grey
Had the same with mine turned out to be the compressor cost about me about £500 for a new one,if it is don't forget to renew the relay as well The careful overtaker avoids the undertaker !
Post #569190 Sun Nov 18 2018 7:02pm
Mickmac
England 2007 Range Rover Sport TDV6 HSE Java Black
I had the same fault ,changed the battery and it disappeared until I put some leds in the stop and tail lights and it came back changed back to normal lamps no more faults !
Post #569205 Mon Nov 19 2018 7:06am
Plazmapete
Had to buy new compressor. Didn't think £312 was too bad until the garage told me it didn't fit. The one they removed was an AMK compressor. The AMK compressor cost twice as much. F@#$ THAT. New alternator.
Gearbox flush.
Post #569563 Fri Nov 23 2018 9:02pm
loadshifter
Glad your all sorted The careful overtaker avoids the undertaker !
Post #569574 Fri Nov 23 2018 11:13pm
Zeoman
Scotland 2006 Range Rover Sport TDV6 HSE Siberian Silver
Try here. Where I got mine a couple of weeks ago
https://nam02.safelinks.protection.outlook...reserved=0
Post #569575 Fri Nov 23 2018 11:18pm
Plazmapete
Thanks I did see this.thort it was too good to be true. Car not sorted yet. Not being done till Monday. New alternator.
Gearbox flush.
Post #569604 Sat Nov 24 2018 8:55am
Plazmapete
Well had the new AMK compressor fitted. Lasted 3 miles then the same fault came up. Any ideas???? It's going back in the garage tomorrow morning. New alternator.
Gearbox flush.
Post #569807 Mon Nov 26 2018 6:31pm
Themoog
Everyone automatically assumes that the compressor is at fault. The light comes on ours every now and then and I thought that was the problem.
I have a scan tool and it told me it is the rear valve block sticking.
When i get chance I may give it a tap with a hammer to see if it loosens the solenoids. If that works then I will make sure I raise / lower the car at least every week to keep things moving.
Post #570263 Sat Dec 01 2018 2:44pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Not a bad idea. I tend to put mine in access height every time I park up just out of habit.
I think the height also lowers a bit at over 100mph but of course there is nowhere legal in the UK to test that 😃
Post #570280 Sun Dec 02 2018 10:05am
Sham91
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Bonatti Grey
I got a suspension fault warning this morning...
Turns out to be compressor at fault....roughly how much labour time is a job like this RRS TDV6 2010 Smile
Post #570343 Mon Dec 03 2018 12:43pm
Page 1 of 3 123>
