![]() | Home > Faults & Fixes > Suspension fault. Normal height only |
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 125 ![]() ![]() |
Mine 'went' a couple of months ago and I was told it's 60mph where the car lowers and that makes a bit of sense in that every time I got to 60, the message came up reminding me to stay at 30!! In my case, the reason was nothing more than a frayed wire - couple of bob at the Indie - sorted. |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 ![]() ![]() ![]() |
Depends what compressor you have. The Hitachi or Dunlop one is around £300. The AMK can be from £400 to £600 depending on where you get it. It's only an hour tops to fit new one. My fault is actually a leaking air resavoir which is being replaced tomorrow. Hopefully it's all sorted then. New alternator.
Well my Normal Height only stayed on, so it went into my indie yesterday and they have confirmed it needs a new compressor. They’re fitting a Hitachi one on Monday and fitting EGR blanks. The car only has 60k on it but is 12 years old.
Well after fitting the AMK compressor it's
Pinnacle Member Since: 13 Mar 2018 Location: Romford Posts: 72 ![]() ![]() ![]() |
Had this on mine for a few days, then when I went to start it one morning. I started to get gear box fault errors, this error, that error, not in park error etc.
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 ![]() ![]() ![]() |
Mine's gone all of sudden overnight.
C1A20 and C1A13 fault codes on mine today, Internet research not much help on this problem as there are so many possible causes to every symptom.
Eskimo Member Since: 21 Oct 2018 Location: Worcestershire Posts: 72 ![]() ![]() ![]() |
If it helps, I had the same fault codes on mine and the fix was a new Dunlop compressor from MM 4x4.
Yep, local Landie specialist says new compressor time for me as well... in addition as the bracket holding the current AMK compressor is snapped I might as well upgrade to the newer type unit.... more $$ but a better quality product and longer term fix apparently. |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
Have a read on the Disco4 sister forum about compressors amd quality. There's a host of threads about rebuilds and air dryer service replacement etc.
So 2 weeks into the new compressor and issues again - same suspension failure orange triangle, joined tonight by a red triangle suspension failure max 30mph drive.
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Who’s looking at it for you 61 AB 5.0 supercharged rocket
What compressor did they fit and what codes are they getting? Kev
