![]() | Home > Maintenance & Modifications > 2010 HSE rotational noise |
It could be a feathered tyre,,ive had this problem loads of times,,sounds like a bearing but it’s a tyre,,rub your hand around the edge or the inside of the tyre & if it’s feathered you will feel a up down motion on the tread.
A few pics I’ve found on internet
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Cheers Andy, I usually give the tyres a visual check at least every week (they get a cursory check each time before I leave home, don't want to drive on a flat and ruin it), but I will get out tomorrow and give them a good look over.
A wheel bearing on the way out? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
That is one possibility that I had considered Tim. That it was MOT'd 4 months and probably only a couple of thousand miles ago, and it not getting louder with an increase in speed makes me less certain. I have had a front wheel bearing go on my D3, which made no noise at all, so I appreciate noise isn't definitive.
Have you driven any gravel tracks or through and mud/stones mixture recently? Sometimes small stones get suck in disc guards on my Defender and can make a similar noise which turns into a squeal until the stone has worn away enough to drop out. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Good god man are you insane, might get it dirty |
Ahhhh a car park queen then |
