![]() | Home > Technical > Anti roll bar bushes. |
Workshop manual: http://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf 2012 SDV6 - it's missing a couple of cylinders
Demaske1 Member Since: 17 Oct 2018 Location: Cheshire Posts: 26 ![]() ![]() ![]() |
thanks but that's the owners manual, not the workshop manual. thanks anyway. |
Are you sure? thought it started with Owners Manual then went to Workshop Manual.
I suggest you look again. |
Sorry about that 😴 |
kevin 2260 Member Since: 27 Sep 2018 Location: SHEFFIELD Posts: 8 ![]() ![]() ![]() |
Hi, mine too had a knocking, the job can be difficult if the retaining bolts don't come out, and you need various 15mm spanners because the bolts themselves are very awkward to get to, I'm somewhat handy, but I had the advantage of having a full time mechanic there that knew exactly how to do the job.
mermade Member Since: 09 Jan 2019 Location: manchester Posts: 2 ![]() ![]() |
its worth upgrading to poly while you are at it https://powerflexstore.co.uk/land-rover/ra...2005-2013/ |
