![]() | Home > Technical > ARC leakage |
duckworthparts Site Sponsor Member Since: 13 Mar 2009 Location: Market Rasen Posts: 674 ![]() ![]() |
OEM aftermarket ARC bar would be £700+vat
The directional valve is quite simple so don’t know why it should fail.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
The Direction Control Valve is part of the valve block, and is not a serviceable item...
Mine spewed all its oil out on the driveway, had all this replaced by Land Rover. Thankfully with a Warranty in place but as the above have said, try Advanced Factors for the OEM parts. Its also a partial rear body lift to remove the rear arc bar too due to space limitations 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
