Home > Technical > ARC leakage
garym74
ARC leakage
Bought a Range Rover Sport 2010 a few months ago. I've had a couple of issues fixed and now the red warning light has come on telling me to stop the car. After a £400 diagnosis from LR, they have said it's the Rear Arc bar leaking and the ARC directional valve. diagnosis and repair £3600 WTF seriously.. why oh why didn't I listen to people telling me not to get one!! Any hints on best place to buy these parts as LR want £1800 for ARC bar alone?
Thanks in advance for any assistance.
Gary
Post #567617 Thu Oct 25 2018 11:01am
duckworthparts
Site Sponsor
OEM aftermarket ARC bar would be £700+vat
find a local indy to do the job and you'll half that repair cost. Sophie Alltoft
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #567619 Thu Oct 25 2018 11:37am
Brit Plumber
The directional valve is quite simple so don’t know why it should fail.
Is it the ARB that’s failed or the pipe? Have you noticed any oil drops on the drive? Was the reservoir empty? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #567620 Thu Oct 25 2018 11:42am
Disco_Mikey
The Direction Control Valve is part of the valve block, and is not a serviceable item...
The issue with replacing the block, is the pipes have to be removed. If they are rusty/corroded and brittle, they may rupture during the repair, and need replacing in addition...
AS Dan says, an OEM ARC actuator is around £700 + VAT
The valve block is £550 + VAT
And all told, I'd allow a days work, but brace you for needing the pipework replacing at the same time...
Post #567625 Thu Oct 25 2018 12:24pm
Buckster
Mine spewed all its oil out on the driveway, had all this replaced by Land Rover. Thankfully with a Warranty in place but as the above have said, try Advanced Factors for the OEM parts. Its also a partial rear body lift to remove the rear arc bar too due to space limitations 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #567629 Thu Oct 25 2018 1:53pm
