![]() | Home > Technical > Front lower arms, should I go for genuine or aftermarket?? |
Meyle HD can be had for a similar price, with a 4 year warranty |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Thanks Mikey.
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I went for aftermarket on mine. Seem fine. £160 a pair on ebay. Steve. |
Call Paul at Advanced Factors and you will be sorted |
Been using them for 2.5 years now, not had an issue |
My initial cheap lower arms on the old sc rrs were nackered in no time. The weight and power just shredded them.
Dr Rob
AF have a few different brands - Delphi etc
I used to use genuine, as they were on a trade offer at £80 each and a 2yr warranty, it was a no brainer Now the prices have crept up and up over the years, they as less appealing I'd be fitting Meyle HD to my own car, if it weren't for the Superpro set I have ![]() |
Begs the question... How much is the superpro setup supplied and fitted ? |
Meyle HD it is then.
Just front lowers or the complete chassis set? |
Cheers lads
From AF?
