Home > General > Smell of Exhaust Fumes in Cabin
215m3
Under normal driving the cabin is free from smells, however if I overtake using the kickdown I get the faintest whiff of exhaust smoke in the cabin. Is this just a poor pollen filter, even though it had a new one a month ago?
I did try searching, but nothing came up 2010 3.0 TDV6 RRS Overfinch GTS
1987 BMW E30 M3 2.4 Turbo
1990 BMW E34 M5 3.6 Trackcar
Post #567272 Fri Oct 19 2018 12:56pm
james5599
Not the clutch making a burning smell?! 2019 Svr and 2019 R35 GTR
Post #567273 Fri Oct 19 2018 12:58pm
Brit Plumber
Is it a 5.0 SC? I have a smell that comes in the cabin when I boot it. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #567274 Fri Oct 19 2018 1:02pm
215m3
I wish a SC, sadly TDV6
Not clutch smell, definitely exhaust fumes 2010 3.0 TDV6 RRS Overfinch GTS
Post #567276 Fri Oct 19 2018 1:14pm
Oldandconfused
Leaking exhaust? Is it blowing at all? Worst case would be a fractured exhaust cross-over pipe, (have a search on here or Disco3) a real PITA to change body on and not cheap for what it is.
Post #567288 Fri Oct 19 2018 5:03pm
215m3
Thanks
The car has a warranty. I suppose I would have to prove it. 2010 3.0 TDV6 RRS Overfinch GTS
Post #567293 Fri Oct 19 2018 8:13pm
MAC
United Kingdom 2011 Range Rover Sport SDV6 HSE Orkney Grey
My daughters 2011 RR Sport has the same issue. Although it has LR extended warranty they will not cover the cost. Initially they said it was due to it being part of the exhaust system. It was pointed out it was actually part of the exhaust manifold system connecting the manifolds to the turbo. They then had a change of heart and said it was not covered due to wear and tear!
Do not rely on an LR extended warranty, it is a waste of money. They will find any excuse to avoid covering any costs despite my daughter having paid into the warranty for 4 years.
Post #567520 Tue Oct 23 2018 2:33pm
215m3
Hi Mac
Thanks for this. My warranty is an independent one, so as the car has only been purchased 1 month ago the warranty should cover it. I believe the company supplying the car needs to make sure it is roadworthy and safe for the first 6 months according to consumer act 2015. 2010 3.0 TDV6 RRS Overfinch GTS
Post #567525 Tue Oct 23 2018 4:35pm
MAC
Hopefully all will be ok then. Quotes received so far for replacing the crossover pipe are in excess of £1,000.
Post #567541 Wed Oct 24 2018 8:28am
215m3
That is useful information. Apparently to test the front pipe start the car, leave to run for 3 minutes and if the engine tone changes it could be a crack in the pipe. It is because the flow changes from one turbo to the other. 2010 3.0 TDV6 RRS Overfinch GTS
Post #567999 Wed Oct 31 2018 8:42pm
Disco_Mikey
Correct. TSOV is closed, which stops the secondary turbo from spinning.
Every 3 minutes, the TSOV opens, which spins the secondary turbo
Don't know if it makes that much of a difference to the noise though
I have also seen the EGR pipes out the back of the valve fracture, causing a noise and smell...
Post #568006 Wed Oct 31 2018 9:30pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Dont Agree
My warranty has been a life saver and never had an issue with any claims on it whatsoever Thumbs Up Thumbs Up
Post #568007 Wed Oct 31 2018 9:32pm
Willis1987
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
Hi what warranty is it you have? Thanks Matt
Post #634234 Wed Jul 12 2023 6:46pm
