![]() | Home > Technical > Transmission fluid |
mikewill53 Member Since: 14 Sep 2018 Location: Swansea Posts: 35 ![]() ![]() ![]() |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 ![]() ![]() |
Capacity is 9.5 litres |
I would be amazed if you need more than 7 litres.
Thanks for all the replies... I was planning on taking however much time is necessary this weekend and do the full flush outlined here
Ordered 20 litres of this https://www.smithandallan.com/products/tra...ternative/ |
Note that is for the full sized RR. The gearbox cooler is different on the RRS. The pipe is near the top of the engine bay, Refer to the link in my link |
Excellent thanks |
I bought this with the intention of pumping the new oil back in through the cooler line.. do you think it will work or should I get something else?
Something else not electric
I thought it would have been better to pump it back in but I'll just do what he did.. im assuming i just put the pipe in the filler plug, bring the funnel higher than the plug and let gravity do the rest |
Just one last thing, its the top pipe in the attached picture that I have to remove on the range rover sport?
Yes
No, only just noticed it on the other thread, I'll have a look over it in work tomorrow. At first glance it does seem to be exactly what I need though, so thanks for that |
