Home > Technical > Transmission fluid
mikewill53
United Kingdom 2006 Range Rover Sport TDV6 HSE Baltic Blue
Transmission fluid
I'm looking to change the transmission oil over the weekend, can someone tell me how much transmission oil a range rover sport 2006 2.7 would take if it was completely empty?
Thanks for any help
Regards
Mike
Post #566185 Tue Oct 02 2018 7:59pm
Red Arrow
Capacity is 9.5 litres
Post #566186 Tue Oct 02 2018 8:14pm
I would be amazed if you need more than 7 litres.
Usually 6 is sufficient
These boxes don't use the regular red ATF.
Use fluid for ZF6HP
26
This is worth a read. Applicable to yours
http://www.rrsport.co.uk/forum/topic52144.html
Post #566189 Tue Oct 02 2018 8:27pm
If you're doing the "empty some out, refill, empty some out, refill" method then you're wasting your time and money. Most of the oil is in the torque converter and is not changed by just "emptying the oil". At best, you remove about 40% per empty cycle. So you end up with a mix of old and new oils.
A full flush requires about 10 litres of oil. It can be done DIY but is usually done someone with a flush machine. 2012 SDV6 - it's missing a couple of cylinders
Post #566197 Tue Oct 02 2018 9:19pm
mikewill53
Thanks for all the replies... I was planning on taking however much time is necessary this weekend and do the full flush outlined here
https://www.rangerovers.net/forum/6-range-...flush.html
Post #566201 Tue Oct 02 2018 9:30pm
mikewill53
Ordered 20 litres of this
https://www.smithandallan.com/products/tra...ternative/
Post #566202 Tue Oct 02 2018 9:34pm
Note that is for the full sized RR.
The gearbox cooler is different on the RRS. The pipe is near the top of the engine bay,
Refer to the link in my link
Post #566217 Wed Oct 03 2018 12:58pm
mikewill53
Excellent thanks
Post #566229 Wed Oct 03 2018 9:27pm
mikewill53
I bought this with the intention of pumping the new oil back in through the cooler line.. do you think it will work or should I get something else?
https://www.amazon.co.uk/gp/product/B00K30...&psc=1
Thanks
Mike
Post #566232 Wed Oct 03 2018 9:31pm
Something else not electric
Use method in your link. Gravity wasn’t it.
A funnel and suitable size hose
Post #566236 Wed Oct 03 2018 9:35pm
mikewill53
I thought it would have been better to pump it back in but I'll just do what he did.. im assuming i just put the pipe in the filler plug, bring the funnel higher than the plug and let gravity do the rest
Post #566241 Wed Oct 03 2018 9:56pm
mikewill53
Just one last thing, its the top pipe in the attached picture that I have to remove on the range rover sport?
Post #566243 Wed Oct 03 2018 10:02pm
Yes
Arrows for fluid direction are for petrol models.
Opposite for diesel
Did you look at the link to the disco site ?
Post #566246 Wed Oct 03 2018 10:19pm
mikewill53
No, only just noticed it on the other thread, I'll have a look over it in work tomorrow. At first glance it does seem to be exactly what I need though, so thanks for that
Post #566249 Wed Oct 03 2018 10:43pm
