![]() | Home > Technical > Can anyone advise? |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 ![]() ![]() ![]() |
Hi All,
The pressure control valve is part of the valve block, and is not a serviceable part |
Thanks for replies. Apologies for confusion but the Red light was on prior to engine work and reading codes (different garage) came up with pressure fault and lots of communication errors. Was about to go in for further investigation when engine broke!
If there’s no fluid returning to the reservoir I’d be going back and asking how/why they could/did have done all this work when the pump appears to be not working.
I am travelling to Chesterfield everyday for next couple of weeks. What do you have in mind?
I’m about 16 miles east of Newark and thought if you were ever passing this way you could drop in and we could take a look. I made a kit earlier in the year to pressurise the system, open the valves in the block and bleed the ARBs. We could also compare to my own as I can definitely see the fluid being pumped back to the reservoir all the time. 2019 5.0 SC SVA (Current)
Sounds like a plan! Will be in touch soon! |
Run the engine and look for fluid returning to the reservoir. It should be quite obvious, if not I’d start looking at the pump, pulley and belt etc.
If you have fluid returning then have a read of that link I posted above and see if there’s anything else you can check yourself. I 2019 5.0 SC SVA (Current)
Hi Brit! Thanks for taking the time to respond.
Not sure but you may have to lift the body off to swap out the bars.
I removed the connectors and refitted them to check (think there were 3 in total). When i was watching the reservoir, i noticed quite a few air bubbles. Is this not normal? If not, how can i bleed the system? |
