Home > Technical > Can anyone advise? |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 |
Hi All,
Tue Oct 02 2018 7:59pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4402 |
The pressure control valve is part of the valve block, and is not a serviceable part
Wed Oct 03 2018 7:51am |
Thanks for replies. Apologies for confusion but the Red light was on prior to engine work and reading codes (different garage) came up with pressure fault and lots of communication errors. Was about to go in for further investigation when engine broke!
Wed Oct 03 2018 7:19pm |
If there’s no fluid returning to the reservoir I’d be going back and asking how/why they could/did have done all this work when the pump appears to be not working.
Wed Oct 03 2018 7:58pm |
I am travelling to Chesterfield everyday for next couple of weeks. What do you have in mind?
Wed Oct 03 2018 8:32pm |
I’m about 16 miles east of Newark and thought if you were ever passing this way you could drop in and we could take a look. I made a kit earlier in the year to pressurise the system, open the valves in the block and bleed the ARBs. We could also compare to my own as I can definitely see the fluid being pumped back to the reservoir all the time. 2019 5.0 SC SVA (Current)
Thu Oct 04 2018 8:06am |
Sounds like a plan! Will be in touch soon! |
Thu Oct 04 2018 9:40am |
Tue Nov 13 2018 7:28pm |
Run the engine and look for fluid returning to the reservoir. It should be quite obvious, if not I’d start looking at the pump, pulley and belt etc.
Tue Nov 13 2018 7:37pm |
Tue Nov 13 2018 7:45pm |
If you have fluid returning then have a read of that link I posted above and see if there’s anything else you can check yourself. I 2019 5.0 SC SVA (Current)
Tue Nov 13 2018 7:48pm |
Hi Brit! Thanks for taking the time to respond.
Tue Nov 13 2018 8:01pm |
Not sure but you may have to lift the body off to swap out the bars.
Tue Nov 13 2018 8:08pm |
I removed the connectors and refitted them to check (think there were 3 in total). When i was watching the reservoir, i noticed quite a few air bubbles. Is this not normal? If not, how can i bleed the system? |
Tue Nov 13 2018 8:13pm |
