![]() | Home > Technical > Towbar Electrics |
Yes just plug in behind bumper on passenger side rear,but it’s a bit fiddly
I bought the 2010 kit as it was the same price as the 2012 kit and just used the trailer harness’ and sold on the 2010 parts. There are blanks (non pinned male connectors) on the female connectors which if you can get the pins, would enable the use of bog standard cabling and connectors instead of the expensive LR items. Had I known earlier, that’s what I would have done. 2019 5.0 SC SVA (Current)
gstuart on Disco3 knows the connector pin type used I think.
The L/R part number for the 13 pin kit on a MY12 car is VPLST0071 and the N & S one is VPLST0070. At £125.00 bit pricey but might be able to use number to cross reference to pattern part or find wiring diagram.
I used VPLST0014 which is for the 10 and 11 MY but only used the 12n & 12s looms (which is the same as you get in the VPLST0070 kit) and sold the other bit on.
There is a sticky in the maintenance section on how to wire up |
That needs updating to accommodate the 13 pin socket as well.
gstuart Member Since: 12 Nov 2017 Location: kent Posts: 3 ![]() ![]() |
Hi
Thank you |
Ur welcome
Thank you |
