Home > Technical > Towbar Electrics
b7cbb
Towbar Electrics
Hi Guys,
can anyone help me out with a part number for the Towbar electrics on MY12 HSE RRS. looking for a 13 pin setup.
I had a look online and there seems to be a few different ones, am I right in saying that the harness just need plugged in?
I already have the Hitch that I kept from Disco 3.
Craig
Post #565846 Tue Sep 25 2018 4:56pm
Tyrefitter
Yes just plug in behind bumper on passenger side rear,but it’s a bit fiddly
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #565848 Tue Sep 25 2018 5:25pm
Brit Plumber
I bought the 2010 kit as it was the same price as the 2012 kit and just used the trailer harness’ and sold on the 2010 parts. There are blanks (non pinned male connectors) on the female connectors which if you can get the pins, would enable the use of bog standard cabling and connectors instead of the expensive LR items. Had I known earlier, that’s what I would have done. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #565849 Tue Sep 25 2018 6:08pm
gstuart on Disco3 knows the connector pin type used I think.
The later RRS require the towbar enabling in CCF
Post #565851 Tue Sep 25 2018 6:35pm
The L/R part number for the 13 pin kit on a MY12 car is VPLST0071 and the N & S one is VPLST0070. At £125.00 bit pricey but might be able to use number to cross reference to pattern part or find wiring diagram.
Don't know if this is of any use just shows which pin are which in the plug.
Found this as well, might help, but may need to go into my gallery to enlarge it so easier to read.
Cheer
Post #565855 Tue Sep 25 2018 7:24pm
Brit Plumber
I used VPLST0014 which is for the 10 and 11 MY but only used the 12n & 12s looms (which is the same as you get in the VPLST0070 kit) and sold the other bit on.
If you get a generic 13 pin plug and loom as shown in Cols pic, I can post the wiring details and part numbers and you maybe able to just buy the pins and instal into your existing male blanking plugs (the blanking plugs are the correct connectors just with no pins) It would save you a fortune. 2019 5.0 SC SVA (Current)
Post #565860 Tue Sep 25 2018 9:03pm
There is a sticky in the maintenance section on how to wire up
Post #565863 Tue Sep 25 2018 9:31pm
That needs updating to accommodate the 13 pin socket as well.
Post #565865 Tue Sep 25 2018 10:07pm
gstuart
Hi
Is it just the pins u want for the terminal block Whistle
Happy to share the link if u want them and where to buy them from
Also made up my own lead for my D3 , so I could charge via the 12s socket
I also fitted a trailer socket at the front of the house , so when I parked on the drive was easy to plug an extension lead in to charge my dual battery set up , charger is in the hallway
Post #565866 Tue Sep 25 2018 10:47pm
Thank you Thumbs Up
Post #565871 Wed Sep 26 2018 11:02am
gstuart
Ur welcome
Here are all the details for the pins Thumbs Up
Paul sells them and is a member of Landyzone / comes under the ebay names of Land Rover connectors
https://www.ebay.co.uk/usr/landrover-connectors
Here are the full details of the connector plugs and pins
http://connectors-catalog.sys.yzk.co.jp/ya...3/025.html
Crimp tool, but if u only doing a few could get away with ordinary crimp pliers
https://www.amazon.co.uk/Hozan-P-706-Barre...B002TKG11G
The plugs are called YAZAKI
Part numbers , quote these to Paul
Male - 7114-4111-02
http://connectors-catalog.sys.yzk.co.jp/ya...nServlet_e
Female 7116-4111-02
http://connectors-catalog.sys.yzk.co.jp/ya...;select=XX
Finding the info took some finding , hope it’s of use to others , can save a few bob then not having to but the complete connector plugs
Hope it helps Thumbs Up
Gary
Post #565874 Wed Sep 26 2018 11:27am
Thank you
Post #565888 Wed Sep 26 2018 6:23pm
