![]() | Home > General (L494) > Front Suspension Knock/Jiggle/Looseness SDV6 - CURED! |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Air suspension/damper unit? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 ![]() ![]() ![]() |
Thanks Wilf - yes it is seeming more and more likely - but as there is no way of telling this is the problem apart from changing it for a new one (expensive, I imagine as they tend to be replaced in pairs IIRC?) I want to cover off all other possibilities first...
Wilf - thanks again for your answer here - out of interest, what makes you think it might be the air suspension/damper unit?
I have read about (but not personally experienced) similar fault descriptions both on RR and Jaguar vehicles.
Thanks Wilf - have got a trustedindependent Landrover Specialist who is going to order in the air suspension unit on sale or return from LR, have a thorough check first and then if he cant' find any other fault he will fit the new part - at least the old one has 50k miles use so it's not a total waste if it doesn't solve the issue!
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 546 ![]() ![]() |
Punkawallah,
Thanks Scrumps - to be fair to the seller (Premium marque garage with good reputation), they replaced a huge amount for me (ARB bushes, lower control arms, drop links plus new tyres and brakes all round) and this improved the initial issue a lot. Most people probably wouldn't notice there is an issue now but I know how these cars should ride/handle!
If anyone’s still interested, I had an inspection done by an independent Landrover garage and the noise turned out to be from looseness/play (about 20mm movement) in the active anti-roll bar. I will try to post the video.
AJ1 Member Since: 06 Apr 2016 Location: Sunshine Coast Posts: 64 ![]() ![]() |
Mine has similar symptoms which have grown worse over my 3 year ownership. Best described as a "popping" looseness in the front passenger side when driving over small bumps in the road. However when turning left (transfer weight to drivers side) and hit a few small bumps, its always there. On inspection, everything seems fine, although Im not an expert. I wonder if i have the same fault ?
Yes - sounds like same issue.
Glad you are getting to the bottom of it, just goes to show how valuable a really knowledgeable garage can be. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Humbug Member Since: 01 Aug 2014 Location: East Anglia Posts: 48 ![]() ![]() |
Same issue over many months but now completely resolved. Had early RRS2 since new (5 yrs/85k miles, lots of off-road) and about eight months ago had bad knocking on front passenger suspension when turning right on full or near-full lock from standstill. Went into Approved Service Centre twice. Nothing seen, no wear etc. Went back in for its service and this time they said it was a known issue: fix was a software update and change of transmission oil. Seemed a bizarre fix for a suspension problem so queried it but firmly told by service manager this was correct. Anyway, since then (two months, 3k miles) fault has not returned. If you want details of the fix shout and I'll find out. |
Humbug, Im SHOUTING....... MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's. |
