Home > General (L494) > Front Suspension Knock/Jiggle/Looseness SDV6 - CURED! |
Humbug Member Since: 01 Aug 2014 Location: East Anglia Posts: 48 |
Bulletin no. LTB00906V6. Action: change transfer box oil and update transfer box control module.
Mon Oct 15 2018 9:55am |
AJ1 Member Since: 06 Apr 2016 Location: Sunshine Coast Posts: 64 |
Thanks, however unsure you had the same problem I have. MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's. |
Mon Oct 15 2018 9:57am |
Interesting, I just googled that Bulletin no. and found this...
Mon Oct 15 2018 10:00am |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 |
Fri Oct 19 2018 6:23am |
UPDATE:
Mon Mar 11 2019 4:38pm |
So all along, it was a loose nut ? MY 14.5 SE SDV6 Loire Blue. Silver roof. 22's. |
Wed Mar 27 2019 1:25am |
No - it was a faulty active anti roll bar with about an inch of play in it.
Wed Mar 27 2019 2:46am |
Just to give a final update on this - as the suspension noise never fully went away, I finally took the plunge to replace the Active anti roll bar valve block as I found a 2020 model one cheaply on eBay. It’s completely cured the suspension knock/rattle/play and I’d recommend it to anyone who has an L494 Dynamic with the suspension noise I described in my earlier posts above. The later valve block is a different design to the early ones (not sure which year they changed) and they seem to have cured the issue. Hope this helps someone! |
Sat Oct 17 2020 6:21pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Great news you got it fixed I also had this issue on my L405.
Sun Oct 18 2020 9:32am |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 |
so if this is a known fault can this be carried by a dealer even though it relates to an out of warranty car?
Sun Oct 25 2020 6:25pm |
It's not a recall so it won't be a complimentary repair. It'll either be covered by warranty or chargeable. Kev
Sun Oct 25 2020 6:45pm |
B Stards! if something was a poor design in the first place then it should really be FOC in my opinion, if it was a wear and tear thing then maybe a small customer contribution would be in order and I wouldnt have an issue with that but from what everyone seems to be saying its was wrong from the start! but then again this isnt and ordinary 4x4 its an LR 4x4 reassuringly expensive!
Sun Oct 25 2020 7:52pm |
Completely agree with you.
Sun Oct 25 2020 8:19pm |
