![]() | Home > Technical > Help! |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 ![]() ![]() ![]() |
Removing front nearside driveshaft from 2007 2.7tdv6 in order to change outer cv joint. Reason for whole shaft removal is outer cv is proving very stubborn to get off shaft so thought it would be easier in vice. All undone but trying to lever at diff end and it's not budging. Was gonna give it a bit more welly but thought I would check that I am not missing anything!
Hi Geoff, finally got it off. but i have knackered the tin dust cover thing that covers the oil seal! I have removed the oil seal itself and are looking for best place to get one tomorrow but where can i get the tin seal thing from?
Hi you may get one from either advance factors on here or dan@duckworths they are sponsors on here or disco3 |
Or Land Rover themselves |
Oops sorry now I see the picture I can see it see if you can get one on eBay that will be your next best bet if someone on here can’t help |
Does it not come as part of the new seal? 2019 5.0 SC SVA (Current)
No, that was what i was hoping! |
