Home > Technical > Help!
GARYF123
Help!
Removing front nearside driveshaft from 2007 2.7tdv6 in order to change outer cv joint. Reason for whole shaft removal is outer cv is proving very stubborn to get off shaft so thought it would be easier in vice. All undone but trying to lever at diff end and it's not budging. Was gonna give it a bit more welly but thought I would check that I am not missing anything!
Gary.
Post #564643 Thu Sep 06 2018 4:45pm
geoffsnook
My off side was a night mare to get off i thought i was going to break something with the effort i put in as long as you are on something solid like chassis or lower arm it should be ok Thumbs Up
Post #564645 Thu Sep 06 2018 5:00pm
GARYF123
Hi Geoff, finally got it off. but i have knackered the tin dust cover thing that covers the oil seal! I have removed the oil seal itself and are looking for best place to get one tomorrow but where can i get the tin seal thing from?
Gary.
Post #564675 Thu Sep 06 2018 8:43pm
geoffsnook
Hi you may get one from either advance factors on here or dan@duckworths they are sponsors on here or disco3 Thumbs Up
Post #564677 Thu Sep 06 2018 8:57pm
geoffsnook
Or Land Rover themselves Thumbs Up
Post #564678 Thu Sep 06 2018 8:57pm
GARYF123
Right, changed intercooler + cv joint. Drive shaft still in vice as i am still trying to locate the tin dust shield! It appears to be part of the actual drive shaft and is peined on the diff side. I managed to damage it levering shaft out of diff. Doe's anybody happen to have a scrap shaft and wouldn't mind levering the dust shield off for me? i am willing to pay of course! The car is stuck in my shared drive until i get this part!
Many thanks in advance,
Gary.
Post #564824 Sun Sep 09 2018 4:23pm
geoffsnook
Oops sorry now I see the picture I can see it see if you can get one on eBay that will be your next best bet if someone on here can’t help Thumbs Up
Post #564826 Sun Sep 09 2018 5:06pm
Brit Plumber
Does it not come as part of the new seal? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #564870 Sun Sep 09 2018 10:03pm
GARYF123
No, that was what i was hoping!
Post #564883 Sun Sep 09 2018 11:40pm
