![]() | Home > Wheels & Tyres > 20 inch rims. |
Just curious but more height in normal suspension setting, for more ground clearance? For what reasons? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
That will just give it a higher centre of gravity for normal driving |
You can get the same result with the OBD Tool if itβs higher ride height you need. 2019 5.0 SC SVA (Current)
Signal drop out...double post. 2019 5.0 SC SVA (Current)
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1191 ![]() ![]() ![]() |
Not exactly what you asked, but I'm running on 255/55R20, very comfortable ride. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
274/45/20 is not an unusual choice. That will give you a little over an inch bigger diameter. |
Have that size on mine |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Not sure what you need the extra 20mm radius for, but if you need more clearance then get an IID Tool and raise the suspension to your liking, +15/20mm up to you.
