Home > Wheels & Tyres > 20 inch rims. |
Just curious but more height in normal suspension setting, for more ground clearance? For what reasons? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Wed Aug 29 2018 5:17pm |
That will just give it a higher centre of gravity for normal driving |
Wed Aug 29 2018 5:39pm |
You can get the same result with the OBD Tool if itβs higher ride height you need. 2019 5.0 SC SVA (Current)
Wed Aug 29 2018 5:59pm |
Signal drop out...double post. 2019 5.0 SC SVA (Current)
Wed Aug 29 2018 6:01pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1175 |
Not exactly what you asked, but I'm running on 255/55R20, very comfortable ride. --
Thu Aug 30 2018 8:31am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
274/45/20 is not an unusual choice. That will give you a little over an inch bigger diameter. 2012 SDV6 - it's missing a couple of cylinders
Thu Aug 30 2018 5:14pm |
Have that size on mine |
Thu Aug 30 2018 5:17pm |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 |
Not sure what you need the extra 20mm radius for, but if you need more clearance then get an IID Tool and raise the suspension to your liking, +15/20mm up to you.
Sun Sep 02 2018 5:08am |
