![]() | Home > Maintenance & Modifications > Washer pump |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
its within the wiring loom
Thanks it does come out of the pipe but very slowly but hardly if any from the nozzle does not seem to make any difference if i take out the one way valves so from the top it goes down under the wing |
Can you blow through the pipe? Cheap screen wash does a good job of turning to jelly. Mine got blocked and I cleared it by running boiling water through the pipe work. Watched all the crap spit out on the screen. 2019 5.0 SC SVA (Current)
Well just pulled the liner can find nothing in there to do with the washers |
What car is it? The L320 has a big water bottle with the pumps and pipe work between the front bumper and wheel arch liner. 2019 5.0 SC SVA (Current)
It is a l320 just had the wheel arch liner off can’t see anything in there to do wiyh it so have bought a bit of pipe to illuminate a few things |
Can get them both working now by taking out one way valves but the spray is really weak so maybe some white Cingular in there to clear the pipes out |
Look at this link, scroll down to Bobs post and you can see a photo showing the location of the bottle on the right of the photo (left of car).
Bobs Gallery showing the topic procedure
Yeah have had all that off mate nothing to be seen there got both sets working but the jets are not even hitting the screen so hopefully the white vinegar will help clean it out as the pump is a new one so all it can be is a blockage or a trapped pipe but can’t see where they really go without stripping out half the top end by the battery |
often cars have a filter in the grommet between the pump and bottle.
Hi mate it’s a new pump and could not see any filter in the bottle itself |
Did you remove the black seal between pump and bottle? |
Yep used the new one that came with new pump |
