Home > General > 2008 Range Rover Sport - Starting issue |
Is the car a left hand drive? It may be worth reconnecting that lock and checking all other connections in that area. I know nothing of the system but assume there will be a transceiver type thing in the door. 2019 5.0 SC SVA (Current)
Tue Jul 24 2018 9:32pm |
Also could be worth replacing the battery in the key. 2019 5.0 SC SVA (Current)
Tue Jul 24 2018 9:33pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
the body processor is part of the fusebox, behind the glovebox.
Wed Jul 25 2018 8:52am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Isn't the battery in the key self-charging? IE has to be inserted into the keyhole and the ignition on to charge. I don't think the battery is replaceable. Does the fob unlock the doors? If it doesn't then try "charging" it for a while until it is able to then trying to start it again. |
Wed Jul 25 2018 9:23am |
